Robot Studio Freezing When Using Physics
Options
I'm trying to use the Physics in RobotStudio 2021.4 and whenever I try to create a cable or set an object's physics to 'dynamic', RobotStudio just freezes. I have to close it and reopen it.
I have tried reinstalling RobotStudio to no avail, and the issue was present for me in other versions. I'm running an i7-10700 2.9Ghz Processor and 64Gb of RAM with an NVidia Quadro P2200, so I doubt hardware is the issue.
Has anyone else encountered this, and how did they fix it?
Thanks
Thanks
Best Answer
I've figure out it is due to using a custom user library for a gantry system, not an issue with RobotStudio. If the gantry library is not loaded I don't get the issues with the physics system. I'll have to rebuild the library and see if that fixes it.1
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 734 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
