How to fix the activation wizard that is currently disabled?
Shwan_Lee
Shwan_Lee
edited March 2022 in RobotStudio
Dear all,
How could i delete the robot studio completely?
This is because the activation wizard is currently disabled.
This seems to be due to the license file.
I need your help.
Post edited by Maxim Riabichev on
  • Hi Shwan_Lee,
    First check and ensure the time and date are set correctly on the PC then do the following:
    On the computer where this error is occurring run cmd.exe (command prompt.)
    Execute command below which will delete the 7.x folder:
    RD /S /Q "%programdata%\ABB\RobotStudio\7.x"
    Execute command below which will recreate the 7.x folder and reinitialize the license storage:
    "%programfiles(x86)%\ABB\RobotStudio 2021\Bin\RobotStudio.Installer.exe" -InitLicenseStorage
    At this point when you start RobotStudio the error should not appear and you should be able to access the license activation wizard.
    Liam
  • Dear Liam,
    Thank you for your beautiful answer.
    You will must deserve novel prize.
    Thanks.
