How can I make it so a digital input sends the program pointer back to the beginning of Main?
I have code that sort of looks like this:
PROC main()
!pos 0
WaitDI diConveyON,0;
!pos 1
WaitDI diRunButton,1;
IF diA=1 THEN
!do A things
ELSEIF diB=1 THEN
!do B things
ELSEIF diC=1 THEN
!do C things
ENDIF
!do A things
ELSEIF diB=1 THEN
!do B things
ELSEIF diC=1 THEN
!do C things
ENDIF
If diConveyON becomes 1 while the PP is in pos 1, I need to go back to pos 0 and wait until it is 0 again. But if it happens anywhere else, it's irrelevant. What's the simplest and safest way to do that? I thought about using interrupts but surely there must be an easier way?
Thanks in advance.
Best Answers
Read up on system inputs in the system parameter manual. There is a signal exactly for that. You have to map it and assign the StartMain action. The program must not be running, or it will be rejected. Issue Stop system input, the STartMain when program is no longer executing.Lee Justice1
If you move the code into a separate routine then you could use something like:PROC Main()
WaitDI di_ConveyOn,0;
RunProcess;
ENDPROCPROC RunProcess()WaitUntil di_RunButton=1 OR di_ConveyOn=1;IF di_ConveyOn=1 THENReturn;ENDIF!the rest of your codeENDPROC1
