Trace of a specific tcp
Greg_F
Hi All,
I have a path with hundred of targets. Along the path I used TCP_a , then later I repass on the same section with TCP_b.
Using the TCP trace, I would like to see continuously the trace of tcp_a for example.
It looks like that the trace switch to tcp_b as soon as the rapid program is using tcp_b, which makes sense.
But I need to visualize TCP_a while it runs the path with tcp_b.
Any I idea how to do that?
I hope my description was clear...
