Activation Wizard is disable to input License
After use 30 days for trials, now my RobotStudio is not let me click to Activation Wizard to install the new license.
Even I have the new premium license, I can do nothing to input the key!!! I tried to uninstall and re-install RobotStudio 2021.04 but still not work.
Does anyone know how to fix this problem?
Thank you!
  • Hi! I realize that this question is old and you probably already solved the problem but for future reference, the solution to a grayed-out activation wizard please follow these instructions:
    Execute the command below which will delete the 7.x folder:
    RD /S /Q "%programdata%\ABB\RobotStudio\7.x"
    Then execute the command below which will recreate the 7.x folder and reinitialize the license storage:
    "%programfiles(x86)%\ABB\RobotStudio 2021\Bin\RobotStudio.Installer.exe" -InitLicenseStorage
    At this point when you start RobotStudio the error should not appear and you should be able
    to access the license activation wizard.
    For a quick answer to licensing questions, you can always send an email to softwarefactory_support@se.abb.com
    Have a nice day!
