how to make a perfect circle in mig welding ???
Options
Small Zone parameters and also divide the segments into smaller pieces. I normally do around 9 points for a circle.0
It's helpful0
You could determine the center of the circle and then use that position, using offset moves to make a perfect circle. You could even make a routine that you can call with parameters such as robtarget and radius to use for the circle.Lee Justice1
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 406 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 736 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
