External variable file
nickel
I want to read in variables to modify program execution from a text file on an external pc. Has anyone any experience of this? Do I need webware? Any comments appreciated.
Nick
You could use either
- WebWare SDK
- Robot Application Builder (IRC5 only)
- Socket Message
Depending on type of controller you may need different options in the controller.
When using WebWare SDK and RAB you need a developer license and for Socket you only need an option to the RobotWare but often it's esier to use WebWare SDK or RAB because they don't need a lot of RAPID coding.Per Svensson
Consat Engineering0 -
Hey nickel
If you have the option "file and seriel channel" you can use the "open"function to open a txt file and read data to your variables.
I have made a drawprogram in vb that makes a text file and the robot opens and read data. Works very well. See here 2007-05-21_171824_Draw_ABB_program.zip
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
Thanks Gents,
Food for thought!
Many thanks
Nick0
