Don't allow LED changing I/O state
Jaycephus
in ScreenMaker
What I'd like to accomplish:
Either in Auto mode, or in both Auto/Manual, disallow controls linked to I/O from changing the state of the connected controller I/O.
Why setting them to 'disabled' in the properties is not good enough:
The text description of the 'LED' control is grayed out to a degree that makes it very hard to read. If only the 'LED' icon was dimmed, but the text remained black, then that would work.
Is there a trick that could be used to keep users from setting I/O during Auto mode? Making a panel overlay the screen with a transparent back-color is not allowed. I haven't figured out any other hacks to accomplish this.
Thanks
Thanks
- Jay
Have you tried changing access rights on the signals in the robotcontroller?
There you can block signals from being changed in auto or/and manualmode.
But still allow rapid to change signal states.Systemintegrator - Web / C# / Rapid / Robotstudio
- 858 RAPID Programming
