leaving parts of a record blank
Hi all,
I wonder if it is possible to hide or skip parts of a record when I don't use them. I use a record to create settings which contains other records which define certain types in my program. Sometimes, my program requires all the types but sometimes I only need 1. Me and my colleagues struggle with the fact it looks and works quite messy when not all types are used. For now I set settings to 0 when the certain type is not use. I wonder if there is a way to skip or hide parts of the records. For example below. I want to only use setpoints_type_2 but I need to fill all of them to let the program run properly. Any suggestions?
In the example below it should be nice if the records with 0 can be hidden.
PERS settings setting1:=
[["TYPE1",0,0,0,FALSE],["TYPE2",100,10,10,TRUE],["TYPE3",0,0,0,FALSE],["TYPE4",0,0,0,FALSE],["TYPE5",0,0,0,FALSE],["TYPE6",0,0,0,FALSE]]
PERS settings setting2:=
[["TYPE1",200,30,1,FALSE],["TYPE2",100,10,10,TRUE],["TYPE3",80,5,20,FALSE],["TYPE4",10,1,10,TRUE],["TYPE5",80,80,80,TRUE],["TYPE6",400,10,30,TRUE]]
RECORD settings
setpoints_type_1;
setpoints_type_2;
setpoints_type_3;
setpoints_type_4;
setpoints_type_5;
setpoints_type_6;
RECORD setpoints type 1
string: type_name
num: speed;
num: zone;
num: acceleration;
bool: calc_speed
RECORD setpoints type 2
string: type_name
num: speed;
num: zone;
num: acceleration;
bool: calc_speed
RECORD setpoints type 3
string: type_name
num: speed;
num: zone;
num: acceleration;
bool: calc_speed
RECORD setpoints type 4
string: type_name
num: speed;
num: zone;
num: acceleration;
bool: calc_speed
RECORD setpoints type 5
string: type_name
num: speed;
num: zone;
num: acceleration;
bool: calc_speed
RECORD setpoints type 6
string: type_name
num: speed;
num: zone;
num: acceleration;
bool: calc_speed
RECORD settings
setpoints_type_1;
setpoints_type_2;
setpoints_type_3;
setpoints_type_4;
setpoints_type_5;
setpoints_type_6;
string: type_name
num: speed;
num: zone;
num: acceleration;
bool: calc_speed
string: type_name
num: speed;
num: zone;
num: acceleration;
bool: calc_speed
string: type_name
num: speed;
num: zone;
num: acceleration;
bool: calc_speed
string: type_name
num: speed;
num: zone;
num: acceleration;
bool: calc_speed
string: type_name
num: speed;
num: zone;
num: acceleration;
bool: calc_speed
string: type_name
num: speed;
num: zone;
num: acceleration;
bool: calc_speed
Hi, this is a interesting question and i'm curious how others solve this kind of issue.
I wrote an example how I do based on your data.
I think it's important that the code is flexible and it's easy for endusers to read and modify the code.
With my method I can change the record structure (amount of setpoint_types or what's included in a setpoint_type) and only have to update the syntax in 3 datas.
And I would not have to do any changes to the programs that don't need the new changes.
Splitting the code in different modules also make's it easier to handle.
First I would create a module called records that looks like this:!*********** !*** MODULE RECORDS !*********** RECORD Programdata string Name; string SetupProc; ENDRECORD RECORD SettingsData setpoints_type_1 spd1; setpoints_type_2 spd2; setpoints_type_3 spd3; setpoints_type_4 spd4; setpoints_type_5 spd5; setpoints_type_6 spd6; ENDRECORD RECORD SetpointData string type_name; num speed; num zone; num acceleration; bool calc_speed; ENDRECORD ALIAS SetpointData setpoints_type_1; ALIAS SetpointData setpoints_type_2; ALIAS SetpointData setpoints_type_3; ALIAS SetpointData setpoints_type_4; ALIAS SetpointData setpoints_type_5; ALIAS SetpointData setpoints_type_6;I also like to have a module for all my data declarations, so I would put these datas there.!*********** !*** MODULE DATAS !*********** CONST SetpointData spdNull:=["",0,0,0,FALSE]; CONST SettingsData sdNull:=[["",0,0,0,FALSE],["",0,0,0,FALSE],["",0,0,0,FALSE],["",0,0,0,FALSE],["",0,0,0,FALSE],["",0,0,0,FALSE]]; PERS SettingsData sdCurrent:=[["",0,0,0,FALSE],["",0,0,0,FALSE],["",0,0,0,FALSE],["",0,0,0,FALSE],["",0,0,0,FALSE],["",0,0,0,FALSE]]; PERS Programdata pdActive:=["",""];Next I would have a module for my programs.
This is the module where endusers would create / edit programs.!*********** !*** MODULE PROGRAMS !*********** CONST Programdata pdProgram1:=["Program 1","pdsetup_Program1"]; CONST Programdata pdProgram2:=["Program 2","pdsetup_Program2"]; PROC pdsetup_Program1() sdCurrent:= sdNull; pdActive:= pdProgram1; !Setup SetpointData #1 !Reserved !Setup SetpointData #2 sdCurrent.spd2.type_name:="TYPE2"; sdCurrent.spd2.speed:=100; sdCurrent.spd2.zone:=10; sdCurrent.spd2.acceleration:=10; sdCurrent.spd2.calc_speed:=TRUE; !Setup SetpointData #3 !Reserved !Setup SetpointData #4 !Reserved !Setup SetpointData #5 !Reserved !Setup SetpointData #6 !Reserved ENDPROC PROC pdsetup_Program2() sdCurrent:= sdNull; pdActive:= pdProgram2; !Setup SetpointData #1 sdCurrent.spd2.type_name:="TYPE1"; sdCurrent.spd2.speed:=200; sdCurrent.spd2.zone:=30; sdCurrent.spd2.acceleration:=1; sdCurrent.spd2.calc_speed:=FALSE; !Setup SetpointData #2 sdCurrent.spd2.type_name:="TYPE2"; sdCurrent.spd2.speed:=100; sdCurrent.spd2.zone:=10; sdCurrent.spd2.acceleration:=10; sdCurrent.spd2.calc_speed:=TRUE; !Setup SetpointData #3 sdCurrent.spd2.type_name:="TYPE3"; sdCurrent.spd2.speed:=80; sdCurrent.spd2.zone:=5; sdCurrent.spd2.acceleration:=20; sdCurrent.spd2.calc_speed:=FALSE; !Setup SetpointData #4 !Reserved !Setup SetpointData #5 !Reserved !Setup SetpointData #6 !Reserved ENDPROCThen in my actual jobProcs I would check the data like this:PROC rType1Job() IF sdCurrent.spd1 = spdNull RETURN; ENDPROC PROC rType2Job() IF sdCurrent.spd2 = spdNull RETURN; ENDPROC PROC rType3Job() IF sdCurrent.spd3 = spdNull RETURN; ENDPROC PROC rType4Job() IF sdCurrent.spd4 = spdNull RETURN; ENDPROC PROC rType5Job() IF sdCurrent.spd5 = spdNull RETURN; ENDPROC PROC rType6Job() IF sdCurrent.spd6 = spdNull RETURN; ENDPROC
Has anyone found a different solution?
The biggest drawback of this method is that the users can edit the programs with "ProgramData" on the flexpendant. But they learn quickly to do it with ProgramEditor.
I like the ability to quickly add more data to the settings, and not have to update old programs that dosen't need the changes.
