Add robot library to RobotStudio?
Hi.
I need to do a simulation with an IRB1300 10/1.15 and this robot model doesnt appear in the robot list when you create a new system.
First:
Where can i download the robot library for this model?
And then:
How can add this file to robotstudio?
Thanks in advance.
  • How are you trying to create your system?
    The IRB1300 10/1.15 appears in the list to create a new solution with virtual controller, is also in the  ABB library list (on the home tab) if you create an empty station/solution...
