Tooldata definition with Z&X orientation
Kappa95
Kappa95
edited July 2022 in IRC5
Dear community,
I am trying to redefine the TCP from the tech pendant of a tool (from which I don't have the CAD) and I am trying to defining with the method of Z&X orientation. I took the first 3 points orienting along X axis the world reference frame. I took the 4th point vertical to the world (as my tool) and X and Z alignments (the last two points) directly blocking along X and Z respectively before moving and saving the positions. I tried different times and I get that Y and Z positions of the tool are almost correct (measuring with the caliber) and X with a positioning ranging from -4000mm and 3800mm. What Have I wrong?
Thank you so much in advance
Best Answer
  • lemster68
    lemster68 ✭✭✭
    Answer ✓
    First, check your calibration offsets and robot zero position.  Ensure that the correct robot model has been installed in the system.
    Lee Justice
