Export the work envelop
Kater
is it possible to export the work envelop as a CAD-Model? A simple STL/DXF would do the job.
If not, is it possible to access the mesh data via API?
thx
thx
Best Answer
Hi Kater,
In the Layout tab you can right click on the Mechanism --> Show Work Envelope. From there you can add it to station and where you, in the Layout tab, right click on the work envelope --> Export.
Best Regards,
Marcus
ABB Robotics0
Hi Marcus,at first I thought that was the solution, but the export function only exports the station, not the workspace.Best regardsTorsten0
Hi Marcus,i used RobotStudio 2021. Is the function available in 2022?Torsten0
- 38 AppStudio
