How to add "IoT Data Gateway" for a virtual controller in RobotStudio?
Options
I use RobotStudio (2022.2, 64-Bit, Version 22.2.9947.0) to run the simulation of a small RAPID program in a virtual controller (ABB.RobotWare-7.7.0). Now, I want to provide the axis values of the robot (IRB6650S_90_390__03) via OPC UA Server. For this, I use "IoT Gateway" (v1.2.1). In "IoT Gateway Config" (v1.2.1.0) I use "Address" as the connection criteria and enter the path of my virtual controller ("C:\Users\<...>\Documents\RobotStudio\Projects\MyProject01\Virtual Controllers\IRB6650S_90_390". The controller is found and a "System ID" is shown but it is marked with "IoT Data Gateway option is missing in RobotWare. Communication with this robot controller is not possible." I think that my controller requires option "3154-1 IoT Data Gateway" to be accessible for IoT Gateway. Now the question: Is it possible to add this option to a virtual controller in RobotStudio? If so: how?
Hello @FrankGumbo
You can add the option using the Installation Manager (Virtual & Real Controllers):
Florian0
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 406 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 736 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
