problem with pack and go in RS2022.1 (bug?)
I always work with stations (not a fan of solutions) recently I used pack and go to back up one of my stations. Now I'm trying to restore it BUT the "unpack to a solution" check box is greyed out. Worse still it is checked, forcing me to unpack as a solution rather the in the original form (a station). Is this a bug in the version of RS i'm currently using?
  • interestingly this only seems to be an issue with pack and go files created with this version of RS. The problem does not exist with older pack and go files.
