Object reference error with RobotStudio Holographic and loading simulation files
Hi, whenever I try to load simulation (.rsstnv) files into RobotStudio Holographic, I receive the message "Object reference not set to an instance of an object". This occurs with all simulation files I've loaded onto the Hololens. The simulation files that come bundled with the application load and run perfectly fine. I've been testing it using the Demo AW Station that came bundled with RobotStudio 22.1.9826.0, and the latest version of RobotStudio Holographic supplied by the Windows Store. I've selected this station because the application is already bundled with a working simulation file of Demo AW Station. The one I export from RobotStudio returns the exception.
