Export DXF Format
I am using RobotStudio 2022.2.1 and I noticed that now when I right click on a object in the Layout tab and pick Export Geometry there is no longer a Format DXF.  Why is this, I used this all the time to Export my layout to DXF so my engineers could use it to layout the cell.
  • It could be a bug.
    I will look into it.
    Maxim Riabichev
    PC Software Support Engineer
  • It looks like the export as DXF is still available, depending on what object you select.
    For example, right-clicking the system in the layout-tab allows me to export it as DXF.
    Maxim Riabichev
