Payload in Axis 5 & 6
Options
in IRC5
Hi, I´am using Roboload for calculate the load in J6 an J5, but I would like understand the way that the software solve it.
I was looking for in the handbook and I found this ecuations.
Ja5 =Load (Kg) x (( z(m)+0.2^0.35)^2 + L^2) + max (J0x,J0y) <= 250 kgm2.
Ja6= Load (kg) x L^2 +J0z<=185 kgm2.
I did the calculations to compare with robotload. For J6 it was correct, manually and with robotload its same , but J5, I never get the output that robotload gets.
thank you in advance for an answer.
best regards
Juan
Can you help to understand how is the calculation?
There are some example or note about that for clear it . thank you in advance for an answer.
best regards
Juan
- 400 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 345 IRC5
- 73 OmniCore
- 844 RAPID Programming
- 20 AppStudio
- 108 Collaborative Robots
