problem with synchronization
dear all,
i've a problem.
1. what i do:
1) copy station and system file from other PC
or change the direcrtory of system on my PC
2) open station and relocate the system file
2. problem:
everything's ok
but can't synchronize path to vc!
output window shows:Synchronization to VC completed with errors. Please double click to view details. details is : [Fatal Error] Sync aborted
why this happens? anyone can help me? TKS.
  • Hi davidseven,
    A system will not work correctly if you change its location and warm start it. You need to cold start the system in the new location, and then restore a backup. I recommend you use Pack & Go to create a package that contains the station, system and backup.
    regards,
    Johannes
    Johannes Weiman
    Software Engineer
    ABB Robotics
  • hi Jonannes,
    thank you for quick reply.
    Pack & Go can solve the problem.
    but I wanna know if there are other solutions when I copy a simulation to another PC? Tks.
    davidseven.
  • hi
    this is the way i have done a copy from one PC to another
    first i copy the mediapool from PC to PC
    Then i save the original station on a networkdrive, and then open the station from the other PC where i have copied the mediapool ,and this works perfectly.
    I havent had any problems doing it this way
    Kent Zibrandtsen
    Dept manager robot welding
    Kez@hardi-international.com
