Request: Double click to view center
Hi.
Since user created RobotApps addins no longer exists, I would like to request the ability to double click to view center.
This was my favourite addin.
Also very useful, but no longer available, was the surface angle measurement.
/David
/David
David
Swedish freelance ABB robot programmer
David
Good idea!
In the meantime I solved this using a custom keyboard shortcut (e.g Ctrl+Shift+C) to view selected object in center. Also very useful if you happen to zoom out through an object and lose track of the rotation center.
@Simmu
I used a shortcut to view center for ten years until I found "Double click to view center" (which was then taken away from RS addin tab). I also had the shortcut as a macro on one of my 3D mouse buttons.
FYI, the "Double click to view center" addin is available again, @Tompanhuhu shared it in this thread:
https://forums.robotstudio.com/discussion/13737/addin-double-click-to-center-view#latest
David
Swedish freelance ABB robot programmer0
- 40 AppStudio
