3Dconnexion mouse to move the robot
Hi all,
Is it possible to use a 3Dconnexion mouse to move the robot, similar to how the FlexPendant joystick operates?
Any research online only shows a manual of an add-in (poly-robotics) but I am unable to find the add-in anywhere.
Any help is greatly appreciated.
Thanks,
Greg
Thanks,
Greg
There was an addin for this, but it's no longer available.
☑️2024 - RobotStudio® User Group1 -
Wasn't that addin only for jogging axis by axis, i.e. no reorient or linear jog?-----------------
David
Swedish freelance ABB robot programmer1 -
afaik, this is correct.Newman said:Wasn't that addin only for jogging axis by axis, i.e. no reorient or linear jog?Systemintegrator - Web / C# / Rapid / Robotstudio
@Newman
@Tompanhuhu
Thank you both for your feedback
Thats unfortunate, it seems like it would be a great feature to be more efficient when programming offline.
If you move the robot to teach targets in the 3D environment, I think you can work more effectively
