First cycle flag in Rapid
dragolollo
edited January 2023 in RobotStudio
Is there a flag in RAPID that states if it is the first cycle after controller power on?
Thank you!
  • Did you ever find anything to do with first cycle? I have a few things I need to do in first cycle only too.
  • Try an event routine for Power On to run a one instruction routine that sets a PERS boolean, e.g. bFirstCycleOnly, variable TRUE.
    PROC rPowerON
    bFirstCycleOnly: =TRUE;
    Be sure to change state of the PERS to FALSE in your production code.
    As an idea in production code
    PROC rFirstCycle()
    IF bFirstCycleOnly THEN
    Stuff
    bFirstCycleOnly: =FALSE ;
    ELSE
    Return;
    ENDIF
