RobotStudio crashes when starting virtual controller after Unpack and Work
Hello.
I have a problem when I try to run my project on other computer. Whenever I unpack the project, virtual controllers stay stopped and after a while I'm getting a Fatal Error (unhandled exception). Even when I unselect restoring backup when unpacking it still happens. Also none of the virtual controllers appear in Controller tab.
  • Are you able to provide a screenshot what the exception says? In the output window you should be able to double-click the exception to see it.
    Maxim Riabichev
    PC Software Support Engineer
