Virtual Teach pendant and Screenmaker "Failed to Initialize"
cmaynard
in ScreenMaker
I'm running the most recent version of robotstudio, and am trying to set up an on-pendant HMI using screenmaker. I am connected to a live robot ( one-click connect ) and when I create any screenmaker HMI and build/deploy it, I get the error message saying it cannot find part of the path.
When I am connected to a virtual controller and use ScreenMaker, I have no problems... only a live robot. Even a blank mainscreen causes this error on my RobotStudio with the live robot.
------snip8<----------------
Failed to initialize Virtual Flexpendant
System.IO.DirectoryNotFoundException: Could not find part of the path'C:hd0a\threebears\PRODUCTS\RobotWare_6.13.4007\vcbin'. at System.IO._Error.WiniOError(Int32 ErrorCode, String maybe FullPath) etc
The solution was that you can't use the virtual flexpendant on a real system ( only a virtual system ). It would be nice if a dialog box popped open saying that rather than a cryptic error message.0
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 341 IRC5
- 69 OmniCore
- 840 RAPID Programming
- 19 AppStudio
- 107 Collaborative Robots
