Getting home position of mechanical unit from PC SDK
Hello all,
This is my first post here and I am fairly new to the whole robot environment so sorry in advance if my question seems easy to figure out.
I am trying to access a certain position ("Home") of a mechanical unit of my controller. I tried getting it through the GetPosition() but I juste got a target, which is good but I would love it to be the name of the position so that I don't have to add a control on the target I got from the method.
Does anybody know if it's possible to get the name of a specified pose of a mechanical unit. I know you can get them through RobotStudio so I assume you can from th PC SDK.
Thank you in advance !
  • Hello.
    I am not sure i understand what you are looking for.
    Get Position will return the current position of the mechanical unit described as a joint target or a rob target, the position does not have a name, it is just a snapshot of where the robot is at the moment of when the method is called.
    Can you elaborate a bit more on what you are trying to achieve?
    Nils Olofsson
    PC Software Support Engineer
