How can I import a backup into Robotstudio?
Hi, I'm new to Robotstudio and was wondering how i can import/restore a backup into Robotstudio. Could anyone walk me through the steps from scratch to import a backup or give me some pointers where I can find information on how to do it. Thanks!
Best Answer
  • SomeTekk
    SomeTekk
    Answer ✓
    You can start RobotStudio (RS), then once startup has completed hit F1 to launch the RS Help document, then search for backup.
    Additionally, under the RAPID tab on the left side there is a tabbed column labeled Files. With Files selected you may open individual files or backups.
    1. Create virtual controller system using installation manager. use required backup file
    2. Add controller ->start virtual controller->select your virtual controller from system pool
    3. (for RAPID and System configuration backup) -controlletr->request right access->Backup ->select backup file which you have use during virtual controller creatation time.
