Suggestion: Drop-down list in Save Current State dialog
Simmu
Simmu
edited April 2023 in UpFeed
I think it would be nice to have a drop-down list in the dialog so you can select an existing state to overwrite. Often when I make RobotStudio simulations I regularly save the current state to make sure my simulation starts with the correct settings (visibility, positions etc.). Since I usually don't want to keep the old state I need to type the exact same name of the state to be able to overwrite it. This would be much easier with the drop-down list. It should be possible to either select from the list, or to type a name if a new state should be created.
 Save-Current-State
