Unable to retrieve 'ElapsedProductionTimeSinceLastService'
I have two identical controllers with the same RW 6.0.8 and I am trying to retrieve the value of ElapsedProductionTimeSinceLastService using the following syntax:
_controller.MotionSystem.ActiveMechanicalUnit.ServiceInfo.ElapsedProductionTimeSinceLastService.TotalHours.ToString()
On one robot, it returns the number of hours worked, but on the other one, I get an error: "Specified argument was out of the range of valid values."
I also have another identical pair of robots, and it's the same - one returns hours, and the other returns the error "Index was outside the bounds of the array".
I am using PCSDK 2022.
Thank you for your help.
- 400 UpFeed
- 20 Tutorials
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 350 IRC5
- 74 OmniCore
- 848 RAPID Programming
- 21 AppStudio
- 109 Collaborative Robots
