[Request] Jobs Backup Date Format
in UpFeed
If there is not a way already, can the Jobs Backup date be formatted the same way it does with the other backup methods? I backup the robots using multiple methods to the same folder and its not easy to view with the different formats.
I create a job with a backup option and a backup name of {SystemName}_BACKUP_{Date}. The result i get is: Controller_BACKUP_08.05.2023
When i backup a controller via robotstudio under the controller tab, i get a format of: Controller_BACKUP_2023-05-08
If i backup via the flexpendat, i get the result: Controller_Backup_20230508
I checked this with robotstudio 2022.3.1
Thanks,
Dan
Thanks,
Dan
Hello @DanielWright
Thank you for highlighting this behavior.
I think both formats should be changed to match that of FlexPendant. Meaning that RobotStudio (via controller tab) and Jobs backups should have this format: Controller_Backup_20230508
I'll ask R&D if this would be possible to implement.
Thanks
