SmartComponent - Properties don't update
Henry123
I'm just wondering, why the Digital IOs in the property window of my SmartComponent don't update according to the signal state.
I can see in the LogWindow of RobotStudio, that the signal "lifePulse" changes its value from 0-->1 / 1-->0 every 5 seconds as it is intended. The Method "OnIOSignalValueChanged" seems to work correct since it is triggering the LogWindow every time when the signal toggles. Nevertheless, the property Windows shows the Signal just on "1" or on "0", no changes.
Any suggestions?
-----Forum.xml-----
------Codebehind.cs-----
Any suggestions?
-----Forum.xml-----
<?xml version="1.0" encoding="utf-8" ?>
<lc:LibraryCompiler xmlns:lc="urn:abb-robotics-robotstudio-librarycompiler"
xmlns="urn:abb-robotics-robotstudio-graphiccomponent"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="urn:abb-robotics-robotstudio-librarycompiler file:///C:\Program%20Files%20(x86)\ABB\SDK\RobotStudio%202023%20SDK\LibraryCompilerSchema.xsd
urn:abb-robotics-robotstudio-graphiccomponent file:///C:\Program%20Files%20(x86)\ABB\SDK\RobotStudio%202023%20SDK\GraphicComponentSchema.xsd">
<lc:Library fileName="Forum.rslib">
<lc:DocumentProperties>
<lc:Author>DEU216531</lc:Author>
<lc:Image source="Forum.png"/>
</lc:DocumentProperties>
<SmartComponent name="Forum" icon="Forum.png"
codeBehind="Forum.CodeBehind,Forum.dll"
canBeSimulated="true">
<Properties>
</Properties>
<Bindings>
</Bindings>
<Signals>
<IOSignal name="lifePulse" signalType="DigitalInput" value="0" uiVisible="true" />
</Signals>
<Connections>
</Connections>
<GraphicComponents>
</GraphicComponents>
<Assets>
<Asset source="Forum.dll"/>
</Assets>
</SmartComponent>
</lc:Library>
</lc:LibraryCompiler>
using ABB.Robotics.Math;
using ABB.Robotics.RobotStudio;
using ABB.Robotics.RobotStudio.Stations;
using System;
using System.Threading.Tasks;
namespace Forum
public class CodeBehind : SmartComponentCodeBehind
public bool simulationRun = false;
public override async void OnLoad(SmartComponent component)
await Task.Run(() => Life(component));
public override void OnIOSignalValueChanged(SmartComponent component, IOSignal changedSignal)
Logger.AddMessage(new LogMessage(component.IOSignals["lifePulse"].Value.ToString()));
private async Task Life(SmartComponent component)
while (simulationRun == false)
if (component.IOSignals["lifePulse"].Value.ToString() == "1") component.IOSignals["lifePulse"].Value = false;
else component.IOSignals["lifePulse"].Value = true;
await Task.Delay(5000);
- 400 UpFeed
- 20 Tutorials
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 350 IRC5
- 74 OmniCore
- 848 RAPID Programming
- 21 AppStudio
- 109 Collaborative Robots
