Collision avoidance subdivision planes
in UpFeed
This initiative
is about the dialog in 'Configure Collision Avoidance, Collision Object
Properties, Convex Hull, Subdivision planes'
After
closing and re-opening the Collision Avoidance configuring dialog all the
defined subdivision planes disappear and the process of setting them up must be
started from scratch. The defined planes should definitely stay in the list
even if the CA configuration tab is closed.
Generally
speaking, using subdivision planes is a bit clumsy way of refining the model. I
suppose there is a good reason to do it like this. Hopefully it'll get easier
in the future. Anyways, Collision Avoidance is a great feature and highly
appreciated!
Kind regards,
Risto
Hello @Risto Virtanen
Please reach out to your local ABB with this request, as it cannot be handled via the user forums.
Thanks!
