skip forward when using motion supervision
I have configured a motion supervision error handler wich is activated by ERRNO=ERR_COLL_STOP, moves the welding torch out for cleaning and back in again.
After RestoPath/StartMove the tool goes all the time back to the point where the original collision happened. If the collision is caused by a big tack-weld for instance, collision will happen again. All attempts to have a bigger tool distance to the work-piece after this point failed.
Is there something like skip-forward in weld-error handler available with collision detection?
