use EGM to command joint positions while getting wrench from FCGetForce
RW 7.8
ABB Gofa
I want to control joint states using EGM using a client pc. At the same time I want to use EGM's /DataToSensor function to send eef wrench's (obtained using FCGetForce) to the EGM client.
This is the code I'm trying to run:
PROC run_egm_joint_server()
    FCDeact;
    FCCalib load_mount_plate;
    ! Register an EGM id.
    EGMGetId egm_id;
    egmSt1:=EGMGetState(egm_id);
    TPWrite "EGM state: "\Num:=egmSt1;
    ! setup
    IF egmSt1 >= EGM_STATE_RUNNING then
        EGMStop egm_id, EGM_STOP_HOLD;
    ENDIF
    ! MoveAbsJ start_j, v50, fine, tool0;
    MoveJ start_p, v30, fine, tool_mount_plate; ! tool_shadow
    IF egmSt1 <= EGM_STATE_CONNECTED THEN
        ! Setup the EGM communication. -> UC uses UDPUC
        EGMSetupUC ROB_1, egm_id, "default", "ROB_1", \Joint;
        EGMStreamStart egm_id;
    ENDIF
    ! Prepare for an EGM communication session.
    EGMActJoint egm_id
                \DataToSensor:=wrench
                \J1:=egm_condition
                \J2:=egm_condition
                \J3:=egm_condition
                \J4:=egm_condition
                \J5:=egm_condition
                \J6:=egm_condition
                \MaxSpeedDeviation:=20.0; ! degrees/s
    WHILE egmSt1 >= EGM_STATE_CONNECTED DO
        IF NOT egmSt1 = EGM_STATE_RUNNING THEN
            ! Start the EGM communication session.
            EGMRunJoint egm_id, EGM_STOP_HOLD, \NoWaitCond, \J1 \J2 \J3 \J4 \J5 \J6;
        ENDIF
        ! force mode stuff
        IF NOT FCIsForceMode() THEN
            FCAct tool_mount_plate; !Activates Force Control – This activates Force Feedback in EGM
        ENDIF
        myForceVector := FCGetForce();
        fill_wrench(myForceVector);
        ! wait to complete egm movement
        ! EGMWaitCond egm_id;
        ! check for connection
        WaitTime 0.004;
    ENDWHILE
    IF egmSt1 >= EGM_STATE_CONNECTED THEN
        TPWrite "Reset EGM instance egm_id";
        EGMStreamStop egm_id;
        EGMReset egm_id;
    ENDIF
    FCDeact;
ERROR
    IF ERRNO = ERR_UDPUC_COMM THEN
        TPWrite "Communication timedout";
        TRYNEXT;
    ENDIF
I can successfully get the real-time wrench, but no EGM joint states that I write to 'output' and send to the Gofa arm get executed.
