External Axis Load Identification
1."Load Identification is not available for this robot type is the Error" when ManLoadIdentify Proc is executed.
(or)
when the below-mentioned program is executed, I'm getting an "Unknown Axis number" error
(or)
VAR bool defined;
ActUnit M8DM1;
ManLoadIdProc\ParIdType:=IRBP_L
\MechUnit:=M8DM1
\PayLoad:=myload
\ConfigAngle:=60
\AlreadyActive
\DefinedFlag:=defined;
DeactUnit M8DM1;
2. The robot is configured with two turntables MID units. When the program is executed, Can I jog it manually without affecting the robot path or execution with an external input?
Need your Help!
Need your Help!
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 341 IRC5
- 69 OmniCore
- 840 RAPID Programming
- 19 AppStudio
- 107 Collaborative Robots
