delete target in AWPP 5.08 [ArcWelding PowerPac]
hi
i have a small problem when deleting targets in AWPP 5.08
if i create a weld in my workobjekt(w_rot1) and afterwards delete it in AWPP, then the targets is still present in the wobj in RS interface and only deletet in the path i am programming in awpp.
This is very anoying and when i afterward rename my targets, and go into RSonline there is a cab between the targetnames, eks p10 p20 p60 p100 and so on.
And for a good order i would like my targets in number order.
Kent Zibrandtsen
Dept manager robot welding
Kez@hardi-international.com
