Routine tooltips
System routines and instructions show a green tooltip in RS explaining what the instruction does. Is there any way to code that into my own routines?
  • Which System routine do you want to implement in your program?
    For example you can run a CBC in the code.
            !     > Executing the CBC
            cyclicbrakecheck;
    Robotic Software Engineer
  • I think he's request is a duplicate of this post
    https://forums.robotstudio.com/discussion/comment/32885
  • Tompanhuhu is correct.
