Is it possible to create a texture from an Image ?
Hello
I am trying to make a texture from a bitmap like this :
Can you help me ? Did I missed a step ?
Thank you in advance,
Alexandre Nicaise
Texture texture = new Texture(image); // image is a bitmapbut I got this error : invalid parameter. I checked if there was a difference in the pixelformat but it was the same.
Alexandre Nicaise
Not a helpful answer, but looks like you are creating a smart component that applies a texture, any chance you made it? I am trying to create the same thing.0
I tried the following code and it worked without exception, where pngPath is the path for a .png figure.Bitmap bitmap = new Bitmap(pngPath);Texture texture = new Texture(bitmap);Material material = new Material(texture);graphicComponent.SetMaterial(material, true);0
- 858 RAPID Programming
