How do I align target orientation?
I am using a saw blade to cut runners off aluminum castings, i need to adj. my end cut position.  i need to align the two targets so the blade will track straight in the cut.  i could rotate the start position then copy orientation and position then re offset the end cut position.  i was hoping for something quicker and easier.
thank you
JD
  • DenisFR
    DenisFR ✭✭✭
    Why don't you use directly Offs function? So only one taught point is necessary.
  • Thank you for the reply, I hadn't thought of that.  I'm new to programing, and I'm learning as I go.
