RS2023.2 Bug - I/O Simulator
I use the I/O Simulator sidebar to turn on signal that are required to run (Fronius TorchClsn input) and just leave it there.  After some irregular interval the pane that displays the I/O signal is blanked leaving only one ai signal, instead of the di and do signals that were there. Closing and opening refreshes the I/O list.
Not confidence-inspiring.  Has anyone else observed this behaviour with the new update?
Rein Purje
Robotics & Automation Lead
Foremost
