Collision error handling while robot is not moving
Hi there ABB robotics folks, I'm integrating a custom positioner with an 2600ID robot. I want to know what signal to take into account if the positioner hit the robot, which is in running mode but is not moving. Even if I moved it in a safe position, I want to be sure that if gets hit, a signal will disconnect my positioner driver,
Thank you in advance
Hallo,in configuration/motion supervision you find parameter collision_detection_at_standstill.Switch this to TRUE to get what you intend.1
