creating new station from template system
sturner
Im trying to create a new station from a template system in RS 5.08.2028.1009.
I browse to C:Program FilesABB Industrial ITRobotics ITRobotStudioTemplate Systems. and select a robot from list. on pressing OK no robot appears and I get an Unkown Error: New station in the output window.
I have seen a similar problem on another PC
Am I doing something wrong?
When you create a system from template in RS 5.08 you don't have to browse to a specific folder to find the system, just click on "Template System" and select a system from the list.
The only folder you have to specify is where the system should be created (location).
ABB Robotics0
