Move Objects
anderer
In earlier versions of Robotstudio you could move connected objects by hand with the coordinate system via Move Position.
Since some time this is no longer possible, instead of the object coordinate system the current tool is selected with which you can move the robot:
Is there another possiblity to move conected objects with the coordinate system?
