HELP, Where can I get the file missing for the back up?
angelkg
Hello, as mentioned in the title, I've been facing difficulties in generating a station from the backup of an older robot. I've attempted to create it using the building tool, but I encountered a couple of issues. Initially, it prompted me for the Robot Ware version 5.12. I proceeded to download version 6 from the add-ins, but now it's requesting an SAC file. I've also tried the same with the STAND-ALONE CONTROLLER in add-ins, but I continue to encounter the same error message when attempting to create the station.
NOTE: THE POP UP SAYS `The media pool does not contain the additional Option: SAC, a system cannot be created from this back up`
NOTE 2: IT ASKS FOR THE SAC version 5.12.4003.04 I have not been able to find it online so far
You need the RobotWare 5.12.X installer. SAC is part of it.
Contact your local (country) ABB Robotics Tech Support for the RW, and if necessary the SAC installer.0
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 341 IRC5
- 69 OmniCore
- 839 RAPID Programming
- 19 AppStudio
- 107 Collaborative Robots
