Array of tooldata
My goal is to have a parametric tooldata that depends on a variable input and use the following:
MoveL AnyPos, v100, fine, ToolInUse{tool_idx};
With ToolInUse being an array of tooldatas defined as
TASK PERS tooldata ToolInUsed{3} := [
                                                            [TRUE,[[x,y,z].......],
                                                            [TRUE,[[a,b,c].......],
                                                            [TRUE,[[d,e,f].......],
and tool_idx an integer from that can take values 1,2,3
I know such a trick is possible with robtarget, e.g.
MoveL Pos{idx_pos}, v100,fine, toolxyz
but I couldn't figure out how to make it work with tooldata in the same way.
Is there any workaround someone knows ?
  • VAR tooldata CurrentTool;
    CurrentTool:=
    CurrentTool;
    Lee Justice
  • Thank you so much for your quick reply, really appreciate
