RobotStudio SDK
Aliwe
while compilation this command: Station station = Station.ActiveStation; makes this error this error : System.TypeInitializationException
HResult=0x80131534
Message=The type initializer for 'ABB.Robotics.RobotStudio.Stations.Station' threw an exception.
Inner Exception 1:
ReflectionTypeLoadException: Unable to load one or more of the requested types.
Could not load file or assembly 'System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'. The system cannot find the file specified.
This means that the connection with RobotStudio through SDK was not established. What is the solution for that?
I appreciate any help!
Hi!
I am facing the same issue right now! Could you please let me know if you get any answer for this query.
Thanks!
What are you trying to do exactly?Johannes Weiman
Software Engineer
RobotStudio Team, ABB Robotics0
