safe IO modules
Hey, we had this issue in the past. So we swapped from to SD_IO_8_Bytes in the E/A Engineering tool. Did u try this one?
You need to get sure that the PLC is also using ur Profisafe F-Parameter and everything should work smoothly
Greets.
Robotic Software Engineer0
