Help for program data in RobotStudio
1-) How can I see the data I created on Robot Studio on Flexpendant?  For example: I created a variable called ("VAR Num Partcount").  When I enter Flexpendant, go into Program Data and enter the Num section, I cannot see any data called "PartCount".  How can I see this?  2-) My second question is how can we see the program data through RobotStudio software?  For example, how can I see the value of a clock data I created called "cycletime" on Robot Studio?  Thank you.
  • If you declared the num variable as LOCAL in a module you can view it by changing the scope to that module.  Otherwise, you should probably have that variable be global.
    A clock does not show the timer value.  You use the ClkRead instruction to put its value into a num variable.  Then, you may view or use it.
    Lee Justice
  • Firstly, thank you. I couldn't understand where to see the program data value in Robot Studio. Could you please tell me where I can see it?
  • Where it is declared, if you mouse over it, it should show the value.
    Lee Justice
    Hi!
    Rightclick the variable and go to "Inspect" than u can see the live value on the bottom of your robotstudio. If you hover over with your mouse the value wont show the changing value.
    https://imgur.com/a/JhMPhyz
    https://imgur.com/a/4GTT9II
    Robotic Software Engineer
