Robot not active.
zforgo
Dear Fellows,
Please help me. I would like the recreate the welding cell with the tourntable mechanism, but as I attached the workobject with the target point to the STN1, but instead of simulation running, the error "50066: Robot not active" error apears and the simulation is hanging. How could I set the robot active through the rapid code?
Thank you in advance,
Zoltan
Zoltan
Hi...Take a look at the 'ActUnit' instruction and see if it works.Att.0
Hi mandolas,
thank you for the hint. I managed to activate the ROB_1 mechanism, but it works only along some movements. I wonder if there is any setup possibility outside the code, because in the example cell (Demo AW Station) I did not see any "ActUnit ROB_1" command in the RAPID code.
Chears,
Zoltan0 -
zforgo said:Hi mandolas,
Chears,
ZoltanI've never had the need to activate 'the robot\controller' in my apps, so other than this tip I can't help you anymore, I'm sorry.I just opened the demo and had no problems running it. I'm using RS 2023.1, maybe that has something to do with it.0 -
mandolas said:I've never had the need to activate 'the robot\controller' in my apps, so other than this tip I can't help you anymore, I'm sorry.I just opened the demo and had no problems running it. I'm using RS 2023.1, maybe that has something to do with it.
Yes, thats the weird, I was able to run it as well, but building the same cell, using the same RAPID code the "robot is not active".
Anyway, thank you for your time! Have a nice holyday and happy new year!
- 858 RAPID Programming
