Robotware not supported
Just updated the robotware from 6.10.2 to 6.15.6 and this message pops up.
https://imgur.com/pUttPf0
I would like to just download one of the versions that is supported instead but since i cannot request write access this is not possible.
I also tried to install the "Flexpendant SxTPU4" from robotstudio and also download to a usb and insert in the pendant, but cannot open it since the only thing i can see is the popup window in the photo.
Any ideas?
Thanks.
  • If you put the controller into automatic while it is powered off, it will start in Auto mode and you can take write access automatically from RobotStudio.
    Thank you but it is already solved, the solution was to download "Flexpendant SxTPU4" to a USB and hold the reset button.
