Path return called on RunRoutineButton press after Jogging
This is a machine running RW 5, when pressing a RunRoutineButton that performs a searchL command successfully and then jogging to a new position and pressing the same button again, the robot returns to the position of the previous button press before running the routine, is this expected?
I have tested with RW 6 and it doesn't return to the first position.
If this isn't expected, is there any workaround or fix for this?
Thanks for any help
Thanks for any help
There is probably a bug in RW 5 or Screenmaker. Unfortunately, there is no further development of both RW 5 and Screenmaker so there won't be a fix for this.0
