[ Bug 2024.1] WorldZone point edition is not possible if VC from Backup
With a Virtual Controller made from backup, in its 'Paths & Procedures', I cannot edit LowPoint and HighPoint for WZBoxDef intruction, only have combo list with pos variables.
With a fresh install VC, it is possible, maybe because there is no pos variables declared.
Even if I synchronize from RAPID with direct value, it is showed correctly but cannot edit it.
In same time I don't see it in 3D view. PS:You have to be sure each values (x,y and z) in LowPoint are lower than in HighPoint.
After I-Start VC, I can edit points values but still don't see it in 3D view.
Post edited by DenisFR on
Still presents in 2024.2.1
I think you are right that it's the presence of pos variables that cause this; you'll get the same behavior if you add pos variables in a "clean" VC. We will look into this.Johannes Weiman
Software Engineer
Fixed in 2024.3.Johannes Weiman
Software Engineer
RobotStudio Team, ABB Robotics1
- 38 AppStudio
